Weird MTL Question (beg?)
Engine work, Tranmissions, LSD's, Diff swaps, etc
labbet
Car(s): 97 na
Postby labbet » Sat Jan 31, 2015 5:58 pm
Hello! I recently replaced my trans oil with redline MTL but when I was pumping the oil up the hose came loose and I lost a hose worth of oil, and when I went to check the level it was lower than the fill hole. I am changing the diff oil soon and it only takes 1/2 a quart... Can I put a little 75w90 gl-5 diff oil in with my 75w-80 gl-4 trans oil??
If not, does anyone have a little MTL that I can borrow a squirt from??
Return to “Power and Performance”
