Who can bore DTB to 64mm?
Engine work, Tranmissions, LSD's, Diff swaps, etc
Hood_Lum
Car(s): 94 Miata
Car(s): 06 FX45
Car(s): 67 Camaro
Postby Hood_Lum » Thu Dec 26, 2013 5:29 pm
Upgraded to skunk2 64mm throttle body.
I can bore out the manifold myself but where can I get the dummy throttle body ported to 64mm?
Went to a couple local machine shops and they all say it's too small and they can't clamp on to it.
94 Miata, 99 head w valve job, MP62, JR cat, Borla cat-back, Koyo Rad, 84mm pistons, M-tech rods, FMIC, 550CC injectors, AGX 8-way shocks, FM mounts, RB springs, BBK, SS lines, RT-615, Hard Dog Extreme, MS2.
Twibs415
Car(s): 01 s4
Re: Who can bore DTB to 64mm?
Postby Twibs415 » Sat Dec 28, 2013 3:29 am
How could they not clamp onto it? Most 3 jaw chucks will be able to clamp that size. its not particularly small.. nor big..
Proud member and Co-founder of the PPRG (Panini Party Racing Group)
Hood_Lum
Car(s): 94 Miata
Car(s): 06 FX45
Car(s): 67 Camaro
Postby Hood_Lum » Sat Dec 28, 2013 11:17 am
Not sure. Took it to 2 machine shop and the told me the same thing.
Called a few motorcycle shops and they don't have the equipment for it either.
alwaysracin
Car(s): lots
Car(s): even more
Car(s): yes
Postby alwaysracin » Tue Dec 09, 2014 8:05 pm
I bolted the Skunk t-body on with out the gasket, used a sharpie and colored the excess metal. You are making it too difficult.
Scott Fraser
gesso
Car(s): Red Exocet
Car(s): Twilight Blue 00
Car(s): 89 Comanche, 06 KLR
Postby gesso » Tue Dec 09, 2014 8:09 pm
The shops sound lazy/like they don't want your business. If they are afraid the wall thickness is too thin to clamp with the 3 jaw, they could always use a 4 jaw on the flange side.
Twibs415
Car(s): 01 s4
Postby Twibs415 » Tue Dec 09, 2014 11:01 pm
we ended up sorting this out. it wouldn't fit in a lathe. got it on the mill with a boring bar and got it done.
Return to “Power and Performance”
Users browsing this forum: No registered users and 3 guests
