Spark plug stripped head
Engine work, Tranmissions, LSD's, Diff swaps, etc
aznpoolpro
Car(s): 1993 Miata
Postby aznpoolpro » Sun Jun 09, 2013 1:20 pm
I was changing my spark plug and noticed that the 1st spark plug was slipping. So I gave a little push on the opposite direction and it would hold so I'm guessing the head of the spark plug is stripped. All the other removed fine. What would be the best way to remove it out without taking the engine head off? My friend suggested a impact wrench but that sounds a little scary.
Re: Spark plug stripped head
Postby Ken P » Sun Jun 09, 2013 6:28 pm
take the head off, inspect and re-tap if you want to do it correctly.
Saphire NB8C
Car(s): 10AE
Car(s): 2007 Lexus IS350
Car(s): Your girl
Postby Saphire NB8C » Sun Jun 09, 2013 8:08 pm
i had a stripped spark plug hole few years ago. had the hole retapped by a shop.
"tits or tires...expect problems."
العريف يوين هو في العراق
طلقة واحدة ، قتل واحد. على استعداد للموت ، وسوف أبدأ!
SoO SpEc Mx5: can't afford gas anymore...can't support the war
aznpoolpro
Car(s): 1993 Miata
Postby aznpoolpro » Sun Jun 09, 2013 8:21 pm
I'm sorry I don't think I was explaining this correctly I apologize. I have retried to remove the spark plug. So what is happening is feels like the bold on the sparkplug is stripped almost like the Spark plug socket is only touching the rim of the spark plug. I was using the correct socket as it work on cylinders 2, 3, and 4. I put a flashlight in the hole but it doesn't look stripped. but I'm thinking maybe the socket isn't in all the way. I don't know it's kind of hard to explain the situation. I'm located in San Jose. If someone has the time to look at it, it would be great. I know for sure the thread isn't seized.
Postby Big Lan » Sun Jun 09, 2013 8:36 pm
aznpoolpro wrote:but I'm thinking maybe the socket isn't in all the way.
Could be. Did the socket part of the plug wire break off and stick on the top of the plug? Is there some crap down in the plug well that's keeping the socket from seating on the plug's flats?
How do you know? You can't get the plug out to verify, it could very well be seized in the head.
Saphire NB8C
Car(s): 10AE
Car(s): Your girl
Postby Saphire NB8C » Sun Jun 09, 2013 11:05 pm
dumb comment, but check the socket for obstruction? yea you removed the other spark plugs but something may have gotten stuck inside the socket before getting to the stubborn one. check the hole the tip of the plug goes into.
aznpoolpro
Car(s): 1993 Miata
Postby aznpoolpro » Mon Jun 10, 2013 9:20 am
Used a compressor to take all the debris out and used a pick to run around the rim. Nothing is there. I can see straight in and it looks fine to me
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Mon Jun 10, 2013 7:36 pm
try running the car for a while and get it up to temp then try removing the plug. also dont use a spark plug socket just use a regular deep 5/8 socket and confirm that it is on the spark plug flats the right way. i wouldnt ever use a impact gun on a spark plug.
Proud member and Co-founder of the PPRG (Panini Party Racing Group)
aznpoolpro
Car(s): 1993 Miata
Postby aznpoolpro » Mon Jun 10, 2013 11:28 pm
Twigs I agree when I heard I'm pact wrench I was like Uhmmthat would ruin my threads.
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Wed Jun 12, 2013 9:36 pm
in reverse it probably wouldn't mess up the threads but its something i wouldn't let either of my impact wrenches ever touch.
Return to “Power and Performance”
