GSL-SE -- turn signals, drivers side don't work
Serving up solutions; one question at a time (Plus tech discussion)
neofreak
Stage ∞
Car(s): 2009 RX-8 GTR3
Postby neofreak » Sun Jan 04, 2015 6:03 pm
Doesn't work with the hazards either, so I suspect it is not the switch. The passenger side works while both signaling and the hazard switch; so probably not the flasher.
I changed bulbs. :mrgreen:
Any ideas?
Re: GSL-SE -- turn signals, drivers side don't work
Postby Big Lan » Sun Jan 04, 2015 7:26 pm
Both front and rear are non-operational? What about the cluster indicator, does that work?
Postby TheOtherRedMiata » Mon Jan 05, 2015 6:06 am
Fuse? Have you tried using the turn signal and the hazards at the same time?
neofreak
Stage ∞
Postby neofreak » Mon Jan 05, 2015 11:29 am
I'm not sure what I did, but I got the signals to work, but the drivers side hazard lights still don't work. At least I can drive it now.
Postby Big Lan » Mon Jan 05, 2015 2:12 pm
According to the '84 wiring diagram (and assuming '85 is the same, if that's what you got, since you like to be cryptic...), the only thing I see that could be a problem here would be the hazard switch itself, or a connector somewhere.
I'll ask again, does the cluster indicator work? And both the front and rear lights are not working, correct?
Put a meter on the Green/Red wire coming out of the hazard switch, that's the output for the left side signals.
neofreak
Stage ∞
Postby neofreak » Mon Jan 05, 2015 2:52 pm
Yeah, 84/85 are the same.
The indicators work when signaling (as do the lights now), when using the hazard lights, only the passenger hand side blinks. (front and rear).
I'm thinking it's the hazard switch too, apparently they are flakey on this car.
neofreak
Stage ∞
Postby neofreak » Mon Jan 05, 2015 3:07 pm
Actually, I'm finding that the whole switch should be taken apart and cleaned -- that could explain why I'm getting random results.
http://intertron.com/ron/combo.html
Return to “Rotary Genius BAR”
