Brake Bias
IHeartRPS13
Car(s): 01' S2000
Brake Bias
Postby IHeartRPS13 » Thu Jul 31, 2008 9:21 am
Heres a guide to calculate brake bias. The reference is for 240s but just plug your numbers and go from there. http://www.sr20forum.com/240sx-s13-s14- ... etups.html
Torqueless Wonder
scottzg
Car(s): A MIATA
Car(s): an old subaru
Car(s): a work van
Re: Brake Bias
Postby scottzg » Wed Oct 12, 2011 6:38 pm
It works for low brake pressure, but it doesn't factor in the proportioning valve...
Ski_Lover
Car(s): 90 DP Miata, 1.8L
Car(s): 04 Prius
Car(s): 06 Tundra
Re: Brake Bias
Postby Ski_Lover » Thu Jun 07, 2012 11:58 am
For those of you wanting more effective brakes on your Miata (which have too much front bias), let me share a popular AutoX trick.
Run more agressive pads in the rear:
Many AutoX folks run OEM pads up front, and Axxix ultimates, or Hawk HP+ in the rear.
I prefer to run the Axxis Ultimates up front, and Carbotech XP-8 in the rear, this gives me outstanding results and wont fade under aggressive driving.
Cheers,
Craig Northcutt
D-Prepared '90 Miata (TC Design Cage & Prep, Rebello built '00 1.8L NA, Ankeny Racing Custom Penske shocks, OSG superlock Diff, 949 15x10 6UL's, Hoosier Tires, 1924 lbs w/50# Rear Ballast)
