New alignment
Popstoy
Car(s): 99 Miata
Car(s): none
New alignment
Postby Popstoy » Tue May 14, 2013 4:36 pm
I just got more agressive, the hell with tire wear. I went from 1.5 neg camber to 2.2 neg camber in front, and backed off the castor a bit. Not a hint of push, while blasting the corners. I left the backs at 2.0 neg. and 1/16 total toe in, never had a problem with oversteer. Bob
Omg10ae
Car(s): 1999 10th AE
Car(s): 1994 miata
Car(s): sold my FD 10/17/13
Re: New alignment
Postby Omg10ae » Tue May 14, 2013 5:44 pm
Bob who does your alignment ? I need to find a better shop.
Now me and the mad scientist gotta rip apart the block, and replace the piston rings you fried!
Ski_Lover
Car(s): 90 DP Miata, 1.8L
Car(s): 04 Prius
Car(s): 06 Tundra
Re: New alignment
Postby Ski_Lover » Tue May 14, 2013 7:02 pm
Need More :)
Edit: I've never got the skinny on R888's, but according to Tirerack they like 1-3 negative camber (less than I expected)
Craig Northcutt
D-Prepared '90 Miata (TC Design Cage & Prep, Rebello built '00 1.8L NA, Ankeny Racing Custom Penske shocks, OSG superlock Diff, 949 15x10 6UL's, Hoosier Tires, 1924 lbs w/50# Rear Ballast)
Saphire NB8C
Car(s): 10AE
Car(s): 2007 Lexus IS350
Car(s): Your girl
Re: New alignment
Postby Saphire NB8C » Tue May 14, 2013 8:57 pm
bob, youre back!
"tits or tires...expect problems."
العريف يوين هو في العراق
طلقة واحدة ، قتل واحد. على استعداد للموت ، وسوف أبدأ!
SoO SpEc Mx5: can't afford gas anymore...can't support the war
minime
Car(s): 4 more Miatas!
Re: New alignment
Postby minime » Tue May 14, 2013 10:42 pm
Interesting - can you tell us what suspension set up you have and what wheels/tires you are using? Shocks/springs/sways and wheel offset in particular.
I assumed most of us preferred more bias on the front end, but you said you were running more bias on the rear until now - did you find it tended to understeer?
I used to run about even on the camber, but am now running the rear a little more conservative. Unfortunately I could only get -1.7 camber max on the fronts so I need to drop the ride height and/or possibly change out my bushings for offset bushings. I have -1.4 on the rear.
A few of my high power turbo'd track buds are running minimal rear camber, but significant front camber(-2.5 front, -1.25 rear) and find it is a great balance.
'93 black&red LE #1455/1500 "GoKart" aka: MiniMe humping the JDM laser(FOR SALE),'94 white &tan "TheTurd" aka: buttmunched, '93 black&red LE #????/1500 "NoNameYet" VVT swap, NB subframes and drivetrain, '93 White C-Pkg "MiniMe" - track Roid racer(broke), '94 Laguna blue & Tan "P729MX5" FM 1 turbo(parts car) & '91 BRG"TheHULK" my ugly new track monstrosity(work in progress)
Popstoy
Car(s): 99 Miata
Car(s): none
Re: New alignment
Postby Popstoy » Wed May 15, 2013 7:15 am
Kaus Racing, in Castro Valley did my alignment. They orginally set up my suspension 6 years ago, after the Tein's Flex's had settled. Back then, I was on some heavy 16 by 7 Enkies with 195/45 T1S's. Today I'm running on a set of 15 by 8 Konig's and 195/50 R888's. They're a 12 pound +25 offset wheel with slightly stretched tires. My ride height is 12 1/2 front, 12 5/8 rear. My right front is camber challenged to a neg 2.2, with max castor of 5.5 and 0 toe. I did have a little push with the old alignment, particularly at entree. With this new alignment, the car feels alot more confident without a hint of understeer. I'm running the big hollow 1 1/4" flyin miata swaybar up front, and a 5/8th's solid jackson racing rear sway in back. The new set up feels fairly neutral, maybe a tad oversteer. I haven't had the oppertunity to test the limits yet. I'm expecting more camber wear up front, and shortly will be headed to Amercia's Tire, for a free rotation and rebalance. I like the R888's, except for the tire noise, but the noise goes away after they get up to temp. Bob
minime
Re: New alignment
Postby minime » Wed May 15, 2013 9:26 am
Nice, thanks for the feedback Bob, this helps us all out figure out what we may want to try on our own cars.
Re: New alignment
Postby rennkafer » Wed May 15, 2013 6:05 pm
You might not get as much tire wear as you'd expect, Bob. My car has been -2.3 front camber, 5* caster, 0 toe in front, -2.0 rear camber, 0 toe for over 3 years and 8k miles on the same 180 treadwear tires (225/45-15 RS-3's). I still wear the outer shoulders the most and have no detectable camber wear on the tires.
There was just a thread on MT.net about this... the big boys (Emilio, Savington, etc) are running 3.5-4 degrees up front and ~2 degrees in the rear. Apparently the more front camber the better, but the rear seems to not improve past 2 degrees. This is on track only cars, of course.
Popstoy
Car(s): 99 Miata
Car(s): none
Re: New alignment
Postby Popstoy » Wed May 15, 2013 7:11 pm
Bill, less or the same camber wear would be great, we'll see. Strange thing is my rear camber has been -2.0 for along time, yet the rear tires are wearing even, with no appearant camber wear. At the same time, the front's with -1.5 showed mild camber wear. I've listened to a few opinions, as to why, maybe the understeer, maybe too much castor, who knows? 2.2 neg up front, with 5.5 castor, solves a bunch of problems for me, no more push, no more tire/fender rub at full left lock. Most importantly, no lift off/snap oversteer, a common tendency when pushing at corner entry. Toyo recomends -6 camber, but that's at full bump, not static, on their R888's. Any how, I had the tire's rotated this morning and went for a 50 mile loop of my favorite twistys, what a world of difference. The car is just so much more confident feeling. Bob
Nikwit
Car(s): 91 NA6
Car(s): 78 Rabbit LeMons Car
Car(s): 55 Belair
Car(s): 79 RX-7
Re: New alignment
Postby Nikwit » Wed May 15, 2013 7:44 pm
What sort of toe did you have? Toe can create wear that looks almost the same as camber. I usually match my front camber (2.3*) to a bit of toe-in, somewhere in the stock range, and get good wear. For a dedicated track car, I wouldn't want the toe-in, but for my DD, it works out fine.
http://www.facebook.com/nikromanoracing
Instagram: @nikromanoracing
Popstoy
Car(s): 99 Miata
Car(s): none
Re: New alignment
Postby Popstoy » Thu May 16, 2013 9:54 am
Nikwit wrote:What sort of toe did you have? Toe can create wear that looks almost the same as camber. I usually match my front camber (2.3*) to a bit of toe-in, somewhere in the stock range, and get good wear. For a dedicated track car, I wouldn't want the toe-in, but for my DD, it works out fine.
It's not toe, cause I'm not running any (read 0 toe in front). Now the back is a different story. I find with the back, I like a little toe in, but half of the factory's recommendation of a 1/16th per side. Without some rear toe in, the back of my car feels like a fish's tail, wagging back and forth at freeway speeds and above. Bob
Nikwit
Car(s): 91 NA6
Car(s): 55 Belair
Car(s): 79 RX-7
Re: New alignment
Postby Nikwit » Thu May 16, 2013 12:58 pm
In a RWD car, 0 static toe up front is toe-out while you are driving, as a result of the road force applied to the tires (look up Scrub Radius if you want to go into detail). If you toe the front in a bit statically, it will result in 0 dynamic toe while driving. Toe it in a bit more, and you get dynamic toe-in, which can help to reduce the effect of camber wear. Go too far, and you lose some of the snappy turn-in feeling. I generally run mine right about at the stock toe number, which works quite well.
minime
Re: New alignment
Postby minime » Thu May 16, 2013 1:07 pm
So is it safe to say if the driver is in the seat during the alignment and you set 0 front toe it will yield 0 dynamic toe(at least when the suspension isn't under compression) while driving?
red5racing
Car(s): 94R, 91A, 92 Sunburst,
Car(s): 95R, 91A Smurf
Car(s): Trek 5900
Re: New alignment
Postby red5racing » Thu May 16, 2013 1:12 pm
FWIW, I have rear toe-OUT and am still alive
94R: no ABS, no PS, no AC, no OBDII, no TCS, no DSC, no ASC, no CC, no PDL, no PW. Just 225/50 Hoosier A6's
Nikwit
Car(s): 91 NA6
Car(s): 55 Belair
Car(s): 79 RX-7
Re: New alignment
Postby Nikwit » Thu May 16, 2013 1:26 pm
minime wrote:So is it safe to say if the driver is in the seat during the alignment and you set 0 front toe it will yield 0 dynamic toe(at least when the suspension isn't under compression) while driving?
No, scrub radius has nothing to do with weight of the driver/passengers (beyond the slight rideheight change affecting bump steer). It's about road force. That is to say, as you roll down the road, the tires/suspension are pushed toward the rear of the car (in most cars, Miata included). The center is somewhere between the LCA bushings, I'd wager. So 0 static toe turns into slight toe-out while moving. The amount will probably increase as you increase speed.
In a FWD car, the power being put to the front wheels has the opposite effect, pulling them toward the front of the car and toeing it in.
Popstoy
Car(s): 99 Miata
Car(s): none
Re: New alignment
Postby Popstoy » Thu May 16, 2013 3:31 pm
You present an interesting theroy, and given with oem bushings it would be even more true. I'm above the ride height, that would produce bumpsteer, plus I'm running polybush bushings for less bushing deflection. The only toe change I'll see with suspension compression is toe out. Given the big air dam/splitter below my front bumper, I only get more down force with speed. Most everything is a trade off, I'll gladly exchange tire wear for handling prowlness. Bob
Nikwit
Car(s): 91 NA6
Car(s): 55 Belair
Car(s): 79 RX-7
Re: New alignment
Postby Nikwit » Thu May 16, 2013 8:00 pm
Popstoy
Car(s): 99 Miata
Car(s): none
Re: New alignment
Postby Popstoy » Fri May 17, 2013 6:29 am
Thanks for that! It explains a few experiences I've sensed, since changing to the +25 offset wheels. I had thought it was simply the wider wheel stablizing the tire contact patch. Now I realize, the smaller offset has given me a neg scrub radius, possibly a good thing. Good in the fact that it causes toe-in for stability at speed, under braking, and a generally improved confident feeling. Bob
