Driving Laguna Seca
Driving techniques on or off a track
Ski_Lover
Car(s): 90 DP Miata, 1.8L
Car(s): 04 Prius
Car(s): 06 Tundra
Driving Laguna Seca
Postby Ski_Lover » Sat Jun 14, 2008 12:40 pm
One of a series by Hank Watts, a well known and respected PCA instructor and author on driving our local race tracks and AutoX schools.
http://www.pca-ggr.org/files/pdf/Tracks_LS.pdf"
Trackpedia.com page for Laguna - includes lap times, other guides, videos, ...
http://www.trackpedia.com/wiki/Mazda_Laguna_Seca
My Note/Additions:
Turn 2 (T2), Pg. LS-8:
The Miata line is the double apex line: you can keep it much tighter between apexes than shown.
T4, Pg. LS-12: Note Skid Marks at Exit.
T6: Note Skid Marks at Exit.
T11: Note Skid Marks at Exit
When you do your warm up laps, no need to speed:
While warming your tires and brakes, note where the flag stations are, and exits with excessive skid marks shooting across to the wall on the opposite side.
Make note to self: "I will NOT be doing THAT". It would seem one of the most common mistakes at the track is to pinch the turn (add steering input when you should be unwinding). If you do this at the exit, and drop a wheel, YOU WILL be adding one more set of these tell tale skid marks. Better to straighten and let 2 wheels off, than to pinch and go across.
Cheers,
Craig Northcutt
D-Prepared '90 Miata (TC Design Cage & Prep, Rebello built '00 1.8L NA, Ankeny Racing Custom Penske shocks, OSG superlock Diff, 949 15x10 6UL's, Hoosier Tires, 1924 lbs w/50# Rear Ballast)
Steve-90
Car(s): 91 miata - gone
Car(s): 14 Audi A4
Car(s): 10 Audi A3
Re: Driving Laguna Seca
Postby Steve-90 » Tue Jul 08, 2008 7:40 am
Ski_Lover wrote:One of a series by Hank Watts, a well known and respected PCA instructor and author on driving our local race tracks and AutoX schools.
My Note/Additions:
Cheers,
Laguna is much easier to go fast than when the berms were bigger about 3 years ago. T6 is actually fun now..not a puckerfest. T9 is still the most difficult for me...with the exit being slightly off camber. I wish I could run Laguna more frequently...but the only way to do that is to run with Skip Barber. :)
old race car - gone
old track car and occasional daily driver - gone
Steve-90
Ski_Lover
Car(s): 04 Prius
Car(s): 06 Tundra
Postby Ski_Lover » Tue Jul 08, 2008 6:10 pm
Steve-90 wrote:Laguna is much easier to go fast than when the berms were bigger about 3 years ago. T6 is actually fun now..not a puckerfest. T9 is still the most difficult for me...with the exit being slightly off camber. I wish I could run Laguna more frequently...but the only way to do that is to run with Skip Barber. :)
Laguna is my favorite. Check out http://www.trackmasters-racing.com/
They do more Laguna and Sears Pt. events than any HPDE group I know of. As an instructor you'll also appreciate that they have well behaved Group A with open passing.
Craig Northcutt
Steve-90
Car(s): 14 Audi A4
Car(s): 10 Audi A3
Postby Steve-90 » Tue Jul 08, 2008 6:58 pm
Might have to try them...but after paying very little to run..or nothing..it is really hard to pony up the bucks just to relax and drive. Get spoiled when you instruct. Ugh.
old race car - gone
Steve-90
Ski_Lover
Car(s): 04 Prius
Car(s): 06 Tundra
Postby Ski_Lover » Tue Jul 08, 2008 10:05 pm
I hear you. I'm doing the same thing.
Cheers
Craig Northcutt
owenxguo
Car(s): S2000 AP1
Car(s): Miata NB
Car(s): E46 M3
Postby owenxguo » Sun Mar 21, 2010 1:27 am
Skip Barber MX-5 challenge current Laguna Seca track record. Nearly stock MX-5 with Koni/Ground Control suspension
tonto
Car(s): '92 mutt (.5 mazda)
Car(s): 3bmw+2.5nissan
Car(s): +1vw = 7
Postby tonto » Tue Jun 15, 2010 8:28 am
T6 is fun. i did my first dry day recently and learned to keep constant steering through T6. which for me is an accomplishment because there is enough movement that i have to fight the impulse to move the steering in the middle of the turn. but i kept it constant knowing that i would land on the other side in about the right spot. by last session it felt really good.
T9 and T3 are quite difficult for me.
It seems T3 apex is actually past the apex. you have to keep turning (while getting back on the gas) which i found very unintuitive. any hints?
T9 is proving hard for me to work up to. if you apex it right, you need to be going pretty fast so the car tracks out where its supposed to (so you get far enough out where the off camber part of the track comes back on camber). however, if you blow the apex, if you are now carrying a whole lot of speed in an off camber area.
mywong23
Car(s): 99 10AE
Postby mywong23 » Tue Jun 15, 2010 11:11 am
suggest getting a ride in some advanced drivers's cars to compare their lines, entry speeds, etc.
Return to “How's My Driving?”
