Will it Pass?
Roadster related topics only.
Brain_zata
Car(s): 04 MSM
Car(s): 91
Car(s): 06 Tacoma
Will it Pass?
Postby Brain_zata » Fri Jun 06, 2014 9:13 am
Who's car passes visual with modified fuel lines/rail. How about cops? How about adjustable cam gears under an aftermarket cover? I was thinking with my AN fuel lines which connect to the hard lines and then to the dual feed rail I could get away with tossing wire loom over all the fittings/hose and some electrical tape, maybe even disconnect one end of the rail and cap that side off. I'd rather not remove the rail since all of the seals/o-rings ect are new & leak proof now and I would also have to remove the AN compression fittings off of the hard lines and reinstall later. You can pm me with "advice" .
More than you can afford Pal
onetwo
Car(s): 1996 M edition Miata
Car(s): 1995 Golf sport
Re: Will it Pass?
Postby onetwo » Fri Jun 06, 2014 10:53 am
In for answers on the adjustable cam gears passing. I'm only asking if they could pass theoretically :)
Brain_zata
Car(s): 04 MSM
Car(s): 91
Car(s): 06 Tacoma
Re: Will it Pass?
Postby Brain_zata » Fri Jun 06, 2014 11:27 am
Well the gears being exposed won't but if you have a uncut cover so they can't see them you'll be fine. Assuming you leave them at 0 so your timing is correct. I on the other hand have a CF cover which will be covering them up but would lead them to think it's there for a reason other than aesthetics. But the shop down the street said if they can't see them then they don't know.
silvermazda
Car(s): 00NB
Re: Will it Pass?
Postby silvermazda » Thu Jul 10, 2014 3:26 pm
um...star smog? depends on the tech. The injector harness throws me off a bit and the AN fitting (hell no!) or at least that's what I think...Unlike another person, I know AN = screams modified!!!! Tone down the colors. That red pipe cover really clashes with the blue. Dead give away.
Return to “Roadster Banter”
Users browsing this forum: No registered users and 3 guests
