gauging interest: sway bar bracket blocks
For Group Buys only. Non-GBs will be removed or deleted.
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Mon Sep 19, 2011 2:18 pm
iv been looking into making small runs of parts to sell and i think the first thing i want to make are sway bar bracket blocks similar to the ones racing beat makes. i can make them for power steering cars or cars without power steering.
As far as price im thinking $20 for non ps and $25 for ps + shipping which i would be $3.50 or free pickup.
if anyone's interested maybe we can get a list going.
Proud member and Co-founder of the PPRG (Panini Party Racing Group)
Oricle
Car(s): '04 Mazda3 Wagon
Car(s): '93 Mazda MX5
Car(s): '71 Mercury Cougar
Re: gauging interest: sway bar bracket blocks
Postby Oricle » Mon Sep 19, 2011 7:59 pm
To late, bought a set about a month ago. :(
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Mon Sep 19, 2011 9:16 pm
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Wed Sep 21, 2011 12:03 am
no one at all huh?
Postby Papa Smurf » Wed Sep 21, 2011 1:34 am
people probably just buy the RB ones.
Miataman28
Car(s): 91 turbo mx5
Car(s): 98 z28
Car(s): 1986 corolla gts
Postby Miataman28 » Wed Sep 21, 2011 7:14 am
Id buy a set!
Scandinavian Flick wrote:Ejecting into the canopy is a euphemism for busting a nut in your pants.
red5racing
Car(s): 94R, 91A, 92 Sunburst,
Car(s): 95R, 91A Smurf
Car(s): Trek 5900
Postby red5racing » Wed Sep 21, 2011 2:25 pm
I'm sorta interested, but you'd need to be clearer about what it is you're building to get me to bite.
Is this it?
http://www.racingbeat.com/Miata-1990-20 ... 54122.html
94R: no ABS, no PS, no AC, no OBDII, no TCS, no DSC, no ASC, no CC, no PDL, no PW. Just 225/50 Hoosier A6's
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Wed Sep 21, 2011 6:36 pm
it would be just like that but id charge less than RB for them. the blocks will be 6061 and depending on cost im thinking i want to use stainless nuts and bolts but if not zinc plated.
one thing i noticed about the racing beat design is that the bolts that you use to preload dig into the blocks and kind of wear them a bit. but they do this so the bolts don't back off. i think a washer with a split washer might be a better solution that way the blocks stay nice and the bolts don't back off.
a little side note i may make an extra coolant reroute or 2 depending on how well mine works first. ill report back with my conclusion.
Postby Ken P » Thu Sep 22, 2011 5:16 am
its not a zinc coating. the bolts that RB gives you are grade 8 bolts, which i believe have more shear strength then standard SS. thats important in this type of application where there is an enormous amount of shear force being introduced into the bracket area. thats the reason why miatas often break the sway bar mount arms. if anything, offer a cheaper alternative to the boxed in arms and ill be in for a set. i know mine is just waiting to snap like it did in the NA.
ps: CNC + SS hardware = you will be hard press to beat their price of $28 and make a profit. you'll need to sell a lot to make up for the prototyping cost.
edit: Stainless Steel Bolts
Stainless steel is comprised of steel alloy with 17 to 19 percent chromium and 8 to 13 percent nickel. Stainless steel bolts have high non-corrosive properties. Stainless steel cannot be hardened due to low carbon content. Despite many misconceptions, stainless steel is not harder than regular steel.
Grade 8 Bolts
Grade 8 bolts are comprised of medium carbon alloy steel. Grade eight bolts have been hardened more than any other bolt grade. This bolt is used in high demand applications such as automotive suspensions. Grade 8 is the highest rating on the bolt-rating chart.
Strength
Stainless steel bolts do not have an indicated proof load. Grade 8 bolts have a proof load of 120,000 pounds per square inch. The minimum strength of stainless steel bolts is 40,000 to 90,000 psi. The minimum strength of grade 8 bolts is 130,000 psi. Grade 8 bolts are much stronger than stainless steel.
garageSTAR
Car(s): AE86
Car(s): TC
Postby garageSTAR » Thu Sep 22, 2011 11:08 am
It's not worth it. I looked into it a while back.
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Thu Sep 22, 2011 2:30 pm
thanks for the info ken. wont be using ss in this application.
anyways im not trying to make money just trying to make some parts for some people.
Postby Ken P » Fri Sep 23, 2011 5:45 am
i dont see the point to be honest. youre better off making a nicely machined coolant reroute kit for under $100. id be in for a set.
Twibs415
Car(s): 94 miata
Car(s): 01 s4
Postby Twibs415 » Fri Sep 23, 2011 9:32 pm
prototyping in progress.
Return to “Group Buys”
